Need help with compatibility
anthonyweaver174
46
Intel - Core i7-8700K 3.7GHz 6-Core Processor
be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler
Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
Samsung - 970 Evo 500GB M.2-2280 Solid State Drive
Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
EVGA - GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card
(NZXT - H500i (Black/Blue) ATX Mid Tower Case.
comes with a smart device for fan control and rgb lighting)
EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Go to this website https://www.nzxt.com/products/h500i-matte-white go down to specifications go down and find System Requirements it says "PC with internal USB 2.0 port" so does my gigabyte z370 aorus gaming 5 have a Internal USB 2.0 it has an external one but does it have an internal one?
The info I refer to is found within the MB specs.
Go here: https://www.gigabyte.com/Motherboard/Z370-AORUS-Gaming-5-rev-10#sp
Quote: "Chipset what does that mean" End Quote:
A Chipset is a group of interdependent motherboard chips or integrated circuits that control the flow of data and instructions between the central processing unit (CPU) or microprocessor and external devices. A chipset controls external buses, memory cache and some peripherals including USB.
The Z370 AORUS Gaming 5 has Internal connections for the following:
1 x USB 3.1 Gen 1 header
2 x USB 2.0/1.1 headers
Quite a comprehensive MB imo regarding USB with enough USB internals for most users.
Do you have the MB already or is this on your wish list?
Any further...
Hi Anthony :) I hope this helps the confusion.
Quote:
"PC with internal USB 2.0 port" should have read "PC with open internal USB 2.0 port and Windows® 10 operating system recommended" End Quote:
It's what the MB supplies and your MB specs state the following for USB
1 x USB Type-C™ port with USB 3.1 Gen 1 support, available through the internal USB header
6 x USB 3.1 Gen 1 ports (4 ports on the back panel, 2 ports available through the internal USB header)
6 x USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
Any further confusion.? explain what you want to do regarding USB.
