Hi! I'm looking for a (cheap) computer case that I can also carry around. I want to do watercooling and case modding and since it is my first build I needed a cheap case to give me some breathing room in case I screw up Anyways my build includes a XFX radeon hd 7970 Ghz edition. I would like to be able to carry the case without damage to the components and I would love if you could help me by explaining me how to mod cases. Once I get that computer and its all set up I might do some final paintwork after learning how to draw in photoshop (can't draw for sh!t, yet) but anywayz thank you and answer quick.
PS: I want to upgrade to Haswell-e when it comes out and that means that I need a case that fits EATX maybe even XL ATX (let's hope it doesn't need to ), will also upgrade to nvidia maxwell and ddr4 so I need a case thats good for carrying (easy to carry as light as possible) and that supports XL ATX (or just EATX dont think that will need XL ATX but never know) handle is a plus and ease of access to drive bays is a plus too. Can be a case from korea or china if it justifies. Will be doing possibly triple loop (3 radiators) water cooling, painting the case myself and installing lighting. Thanks for your help and time
PPS: Max budget is 100$ but I want it to be as cheap as possible in case I screw up
PPPS: If you can point me some case modding tutorials or give me such a tutorial I would be very grateful.
