need help with Cooler Master Silent Pro 1000W
drakehotbling
37
hello.. just upgraded my gpu from gt610 to gtx 1060 3gb , so i used my old powersupply cooler master silent pro 1000W , i found all of the cables but one which is the sata cable that i should put inside the power supply then connect it with my HDD , i went to ask around and some people say that it has to be the same cable as the one i lost and some of my friends says that no..i dont know about volts and this kind of stuff and need serious help please guys.. what should i do?
+ another question , the fan of the power supply is not working , did i plug something wrong or does it work automatically when its hot? thanks !
the psu it self is just working fine ! tried it yesterday several times !
