Need help with CPU cooler issue. I purchased a new CPU and MOBO and bought a new CPU cooler I installed the cooler per instructions and had CPU temp at around 60C when idle. I swapped the cooler for another one thinking something was wrong. After instillation I got the same idle temp at around 60C.
I'm pretty sure I installed everything correctly, the only thing that may influence the temp is that some of the thermal paste fell off the top of the CPU; it did NOT go on the MOBO or even the green edge of the CPU, only on the metallic side of it. WOuld this affect the temp?
CPU: i7-6700k
Cooler: Enermax ETS T50
CPU: i7-6700k
