You could try taking it to a shop, which time depends on the shop you go to. Bent pins can be hit or miss, there might be permanent damage to the pins, or they might be able to fix them. The route you take is up to you, good luck!
there is only one way that the CPU will slip into the slots. There is a corner cut out usually that will block the CPU from being installed any other way than proper way. it looks right, and bottomed out to the holder.
CPU fan... well you need to clip the CPU in first with the original retainer from motherboard.
is your CPU fan aftermarket? or stock one?
stock one can be installed in many different ways usually, is not a problem if the wire to power the fan reaches
aftermarket fans you want the fan to sit vertically, so that it can pull air from front of PC case and out towards back of the PC case where the hot air gets taken out of the case
but, it would be very good for you to watch some youtube videos as you can see on hand how to do it properly
The CPU is well placed in the first picture (notches matching the socket ones), but there seem to be 2 bent pins in the socket. Try straightening them.
https://m.imgur.com/a/WyOh8
I think my motherboard is a goner.
Does any know if the motherboard had any hope if i get it looked by someone else. Also would it take a long time else i'll probably have to look for a new one .
