Need help with cpu really badly
Jul 11, 2018
5
I need help I bought a new cpu for my computer and I installed it with the fan and the display didn’t work so I went to these forums and I looked for a answer and someone said to do I cmos reset by removing the battery and waiting five minutes and putting it back in so I did that and that didn’t work so I put in my old cpu and tried to update the bios (forgetting that I reset them) and I don’t know what to do because my pc won’t display anything and also I went to cpu upgrade and it is compatible with my motherboard
My motherboard is a gigabyte GA-F2A68H-H and my new cpu is a AMD Athlon II A4 860k black edition
My old cpu also stopped working with my computer when and it’s display so I
cannot use when retried using it after putting it back it
I don’t think I my bios was fully upgraded
When you reset the CMOS did you follow the procedure on page 14 of the user manual.
Do you have your monitor plugged into the motherboard graphics or into an add on card.
Do you get any BIOS screen?
Do you have both power cables connected to mother board (4 pin near CPU and 24pin), do you see any lights?
No I don’t have the Manual anymore I looked it up on the internet
I’m using my motherboard graphics card
No I did not get the BIOS screen
And I have a 20 pin and a 4 pin
