C Chef_Eddy Distinguished Sep 3, 2015 17 0 18,510 Jan 1, 2019 #1 Hi guys, I just built my first computer and I need help. I have a LG 27MP59G monitor with a AMD 570 4g video card. What exact display port cable do I need to buy. There are so many different connections. Need help The Noob
Solution T T Tumeden Jan 1, 2019 Based on the specifications to your monitor and GPU, they both have display port connectors. So a simple DP to DP cable should work fine. https://www.amazon.com/Moread-DisplayPort-Gold-Plated-Compatible-Projector/dp/B01N0ZHJFQ/ref=sr_1_2_sspa?ie=UTF8&qid=1546390861&sr=8-2-spons&keywords=displayport+to+displayport&psc=1
geofelt Titan Oct 9, 2006 55,388 4,564 174,240 Jan 1, 2019 #2 You can buy any displayport cable that is suitably long. DP will be the better performing connection. Upvote 0 Downvote
T Tumeden Honorable Oct 15, 2016 449 0 11,160 Jan 1, 2019 Solution #3 Based on the specifications to your monitor and GPU, they both have display port connectors. So a simple DP to DP cable should work fine. https://www.amazon.com/Moread-DisplayPort-Gold-Plated-Compatible-Projector/dp/B01N0ZHJFQ/ref=sr_1_2_sspa?ie=UTF8&qid=1546390861&sr=8-2-spons&keywords=displayport+to+displayport&psc=1 Upvote 0 Downvote Solution
