Hello, a while ago i bought a budget ''Ryzen 3 2200G '' gaming pc. but after trying to play BF V on it i get around 55-70 fps ( really depends ) but some days its not going higher then 28-33. so i thought the 4 cores are the problem. so im thinking about upgrading my pc.
i was thinking about buying a AMD Ryzen 7 2700X since it has 8 cores and runs at around 3,7 Ghz. will this make it run better? ( i know i have to get a seperate graphic card )
my current build
AMD Ryzen 3 2200G 3.5 Ghz ( looking to upgrade it with a Ryzen 7 2700X )
2x 8GB Hyper X Fury 3200Mhz
64 bit Win 10
BeQuit! PSU 300Watt ( will need to upgrade this one too )
graphics card : im thinking about getting a geforce-gtx-1050-ti
the problem is though. will the Geforce work on the AMD motherboard? and does anyone recommend anything else? my budget for this month is around ~450 Euro's
any help is appriciated.
my current build
64 bit Win 10
