Hello everyone,
So I am building in the Meshify C and both my CPU and GPU will be cooled with AIOs. CPU one is 280mm and the GPU 120mm. However with both of these I am a bit lost as to the proper fan configuration. The top can have up to 280mm worth of fans as well.
The 280mm will be at the front as intake, with the 120mm attached at the rear of the case as exhaust. Should I have another 120mm on the top as exhaust?
My only concern is the 120mm aio fan would not get enough air to exhaust and cool temps down with. Should I make the top 120mm intake instead of exhaust? What do you all think would be the best fan configuration?
