Need Help With Gigabyte Wifi Card And Ethernet Driver
FallingGravity
25
I just built my first PC and installed windows 10 successfully on it. But while I was installing the drivers I came upon an error message when installing the Ethernet driver. I got the Ethernet driver directly from ASUS (my motherboard is the z170-A).
The Error Message:
Error 1311.Source file not found
E:\Drivers\Lan-Ethernet\Intel_Gigabit_Ethernet_Win7-
81_v20230010_Win10_V20240010\...\DMIX.cab.
Verify that the file exists and that you can access it
I deleted the driver and re downloaded it to try again but it did not work. I wasn't planning on using the Ethernet anyways so I tried using my WiFi card I got. I am not really sure what the issue is with the WiFi card because I installed the driver for it from gigabyte (the card is the Gigabyte
GC-WB867D-I) but I go to the WiFi thing in Windows 10 and nothing comes up. I have no clue what I did wrong with both of these things. Any answer would be great, thanks.
OK I installed that driver and now I can see my WiFi along with others. That's great and thanks but when I try to connect to the WiFi it says it can't connect right now
Yeah sorry I actually did restart the system after I was done installing the driver. I just reset my router and it still isn't letting me connect
