Question Need help with H150i fans not being detected after a firmware update
Nov 23, 2024
9
Hi all!
I had a question about my H150i ELITE which has been working fine for over a year now. ICUE showed that there is a firmware update which I went ahead and installed. It would show that it’s updating but it wouldn’t change its firmware for some reason. And then I saw that the cpu fans are running at the same speed and slightly loud. I couldn’t change the cpu fans speed and so I restarted the computer. Then there was a bios error saying it can’t detect cpu fans. I changed the monitor setting to ignore so I could boot up windows. Now the cooler does not have any lights and the cpu fans run at the same speed. How can I fix this?
Thanks
Nov 23, 2024
9
Yeah I tried the Corsair forum too. This issue is so bizarre, after contacting so many people and places, literally no one has any idea what to do. The cooler is being picked up in the "Bluetooth and other devices settings" and also somehow in ICUE under the software updates. But still for some reason it does not want to work. Do you think it might be because I set the bios monitor settings to ignore the cooler fan speed and stuff which is why its not even trying to detect it?
Colif
Win 11 Master
i think the firmware messed it up, as it was working fine before you did that. Its possible they can send you a firmware that fixes the issue or at least, takes you back to a working version.
i had a problem with Icue last year where my pump was making weird noises and fans would randomly not start with cooler. I took the hint as it was almost summer and I didn't need fans that don't always start
Colif
Win 11 Master
if you get an answer, post it here as it could help others :)
bottom answer might help
9
Oh sorry, it was in the "clink" folder. Also do you have the 1.02.7 firmware file, this was the one I was originally on and I am reading a few posts and have found out that 1.02.8 bricks up everyone's cooler? I need to drag that file into the folder.
Nov 23, 2024
9
yep I was in that reddit post. supposedly the Corsair team does not have the file to manually do it either as one user has said. And also I dont see anyone that has the file. As for that answer that you previously sent with this same method, the person specifies where to get the files to put into the XMC file. But the ones I have are all 1.02.8. So they just dont work.
Colif
Win 11 Master
It looks like Corsair are only answer.
I have latest version of Icue installed only as I still use it to run the RGB on my ram.
I wonder where it puts the drivers. I wonder if the installer replaces the previous one by over writing or just installilng newer ones. I know Microsoft tends to collect drivers in driver store
might help - https://learn.microsoft.com/en-us/powershell/module/dism/get-windowsdriver?view=windowsserver2022-ps
You can also use Device Manager to find drivers:
  1. Open Device Manager
  2. Find the device you want to update
  3. Right-click on the device
  4. Select Update driver
  5. Click Search automatically for drivers
https://github.com/lostindark/DriverStoreExplorer
thats assuming its still there.
slaps self and realises its firmware, not drivers... where it would be stored is an even more mysterious thing
9
Yeah thats the issue with firmware, just so complicated. Now the best thing to do is just wait and see what Corsair says as you have said. Will keep posting here about the process and once resolved, I will give the steps to solve this issue and also the 1.02.7 firmware file for anyone else having this issue.
