Question Need Help with Half-Configuration Im gonna buy
amkokole123
13
So i saved some money from my birthday and i wanted ti upgrade my current one cuz it needs badly
MOBO
CPU and ram
Current: i5 3470
MOBO H61-M
8 GB DDR3
GTX 1060 6GB EVGA
Its pretty bad cuz firstly cpu is bottlenickin hard and overall i want something better to game on and get good FPS for gaming, and something good for work.
So i found nice deal (for my country at least)
Ryzen 5 1600
8GB DDR4 Trascend 2666Mhz
ASUS A320M-K AM4/DDR4
■The Price for this half configuration is (200 euros or 220/230 usd its all brand new with 3 yeah warranty)
■NOTICE🙁 i don't order from amazon, or ebay, or similar sites cuz shipping fee is just horrible... and i usually wait a minimum of 3 weeks... and i know i could get it for much cheaper but this is "cheap4my place"
■Also something very important is my PSU
I have 550 watt called Falcon FLC-550L
I bought it a year ago from my local component store (its basically like a best buy in my country ps: we dont have best buy or walmart or other things, just so you know)
■and my question is will this psu MAYBE be able to power this system, i boughted just bcuz i needed 6pin and some more cable's (sata ect.) And didn't care about quality, but it seemed good back then..
These are some specs from my site
1x 20+4-pin, 1x 4+4-pin, 1x PCI Express 6-pin, 4x SATA, 2x PATA, 1x FDD cooler 120 mm Protection Short circuit protection, Overvoltage protection, Undervoltage protection Efficiency 70%
■And here is the link from my site if you can't find it on google https://www.winwin.rs/napajanje-550w-falcon-flc-550l-6812379.html
■If it's not good (and i think its really not for the system i want to build) what are your guys recommendations, for good budget PSU (budget would be somewhere between 40/50 dollars or 40 euro's)
Do you think my Ryzen build is good for gaming at high resolution ?
Sorry for lengthy post i just want to make sure everything is okay.. since i can't make mistakes
