NEED HELP with hard disk ASAP
WokerGaming
47
Today i installed 212 evo on my gd65 990fx and 8350 processor,while doing so i had to plug off all attached to mobo and then reatached it,when i first started computer after retaching i saw smoke comming out of hard disk and fastly disabled power supply to stop it,but now when i plug white part of cable which goes from mobo to hard disk (little white cable) everything starts up but when i try to plug (i think its double bigger in lenght and it goes from plug next to processor and into hard disk) my computer doesnt even start but when i plug it off everythings goes perfect (ofc theres no booting but i get this message
EFI Shell Version 2.31 [4.633] Current running mode 1.1.2 Map: Cannot find required ma name
Press Esc in 5 seconds to skip startup.nsh, any other key to continue
i have 500 gb hitachi storage which is about 6-7 years old and was working perfectly
after my mobo logo goes i get efi message i wrote and thats about it,please someone give me advices about this since i have about 100 gigs of video editing i was doing
my full specs
R9 280X overklokovana na 1150
Procesor:AMD 8350
212 EVO
RAM:2x4GB Patriot Viper 3
Maticna ploca:990FXA-GD65
630w thermaltake powersupply
Smoking hard drive = might as well be dead.
I have never heard of a smoking hard drive before. Are you sure nothing else was smoking and you thought it was the HDD?
Can you plug the HDD into another PC to see if it shows up? However if you need that I recommend paying for professional recovery.
i just tried it again and whenever i try to start pc with hard disk plugged my computer with both of cables attached to motherboard it doesnt start at all,but asap i remove them my compiter starts totally normally and just ask for bios disk
when i tried to boot it with hard disk it started to stink a bit like something is burning etc,any way to recover this hard disk,i will try to plug it in to another pc and see how it goes on
ps:any way to save data from dead hard disk?
ty for answer
