2008 Gateway FX 4710
Intel Core 2 Quad Q9300 @ 2.50GHz
6.00 GB Dual-Channel DDR2 @ 332MHz
Gateway G33M05G1 (Socket 775)
512MB GeForce 9800 GT
Hello, I am trying to upgrade the hardware parts in my computer to make it even more up-to-date and better for gaming, but I need some help. My first question is, if the hardware I posted below will all fit into my computers case without any issues because I am not familiar with the sizes/shapes of the hardware nor of my case. (You can find my system specs in my profile i believe, but i also posted the stats on the top of this message just in case.)
Second Question, I am basically trying to purchase these items listed below, but I was wondering if they will all be installed and work together properly without and problems since I don't really understand if these parts are compatible with each other. Also, which one of the motherboards am I better off with. Here is the list:
1) Intel Core I5-2500k Processor
2) MSI P67A-C43 B3 Intel P67 Motherboard - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7325818&CatId=6978
OR
ASUS P8P67 LE B3 Intel P67 Motherboard - http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=7343083&csid=ITD&body=QA#
3) EVGA 01G-P3-1461-KR GeForce GTX 560 Superclocked Video Card - 1GB - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=555335&CatId=3669
4) And a recommended power supply to handle everything. I was thinking at least 700 W power supply
FEEL FREE TO OFFER SOME BETTER UPGRADES,
ASK QUESTIONS (ill try my best to answer),
AND PLEASE LMK IF THESE WILL ALL WORK TOGETHER.
THANKS!
OR
THANKS!
