hi guys, Im having trouble with my computer. My hard drive is not showing up in the bios. im certain that its plugged in all the way and have tried using different wires for both power and sata with no luck. the power is plugged into the same plug on my psu that my graphics card was in and i know it works. and the data is plugged into a sata in the 3rd sata port on my rog strix z370-e gaming mobo. the hard drive is spinning up at first before the computer fully turns on but then stops before it boots or as soon as i open bios. i am booting from a (not sata) m.2 drive, the samsung 960 evo.
the sata ports have never been used for anything before and this is a brand new (less than one month old build all parts new from box).
before this issue i had an issue with a corsair h115i water cooler that didnt seem to want to even turn on or light up and i just gave up. I'm temporarily using a aircooler but thats an issue for another day. i just wanted to throw that in there. thhe only similarities between these problems are they both use the same type of power connection from my psu (the double wide sata type power plug) but i can feel the hdd spinning for a few seconds so idk what it could be. i have updated bios to the newest version as well to see if that would help but no luck.
ive been a lurker at this community for a while now but this is my first post / question. im really scratching my head here on this one, im wondering if maybe the mobo is bad? everything else works fine though and the computer is very quick. This is running on windows 10
