So my CPU cooler came the other day so I figured I would install it this evening. I am having an issue with it.
Everything was going well. But the little plastic backplate thing that comes with it won't fit on my motherboard. It won't sit flush and the little peg parts that the screws go into won't all fit in the holes on my motherboard.
You can see the little plastic backplate here in this article.
www.realhardwarereviews.com
I believe it's supposed to sit flush and all the little pegs are supposed to go into the holes on the motherboard.
Motherboard is an Asus H170 pro gaming. The socket is an 1151. It should fit but it doesn't.
I hope someone can help. I guess I will try and contact Arctic as well.
So I bought and tried to install the Arctic 34 Esports Duo. My problem is that the little plastic backplate that came with it doesn't fit right. It's a socket 1151. It should fit but it doesn't. My motherboard is an Asus H170 Pro Gaming.
So I was thinking would it be possible to just buy another backplate? Like from another company?
Does anyone make them? If so where could I get one?
I guess I could try Newegg.
Arctic Freezer 34 eSports DUO Review
Arctic Freezer 34 eSports DUO In the past we have made mention of the manufacture formerly known as ‘Arctic Cooling’
