Need help with installing drivers on msi z68ma-ed55 (b3) motherboard.
Loyde Kessroy
Commendable
Apr 11, 2017
69
I need a description of how i can install the right bios and drivers on this motherboard because i'm lost. From what I know, I need internet and graphics drivers, and I can get to the msi support website for them, but I don't know which ones to download and how I install them later from the used flash drive.
Type AMI BIOS Language English
Release Date 2013-01-09 Version 11.1
File Size 5.98 MB
You want that latest bios release.
http://www.realtek.com.tw/DOWNLOADS/downloadsCheck.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
You want this, don't bother with the ones from msi, because they are outdated.
Type On-Board LAN Drivers Title Realtek PCI-E Ethernet Drivers (W8)
OS Win8 64, Win8 32 Release Date 2017-01-03
Version 8.47.714.2016 File Size 9.69 MB
File Download
Description Network Driver
You want this too be sure to download it
Type System & Chipset Drivers Title Intel Management Engine Driver
OS XP 32, XP 64, Vista 32, Vista 64, Win7 32, Win7 64, Win8 64, Win8 32 Release Date 2012-08-30
Version 7.1.52.1176...
D
Deleted member 1443762
Guest
You just run them. Start with the chipset driver. Almost all of them will have a .exe inside their Zip or folder(s), which you just run.
https://youtu.be/RxaVBsXEiok 18:44
Use another PC to download them, then copy them to a USB drive. Go from there.
File Size 5.98 MB
File Download
Version 7.1.52.1176 File Size 3.94 MB
File Download
Note For Intel ME FW 7.1 system
Like xniosy mention you will want this as well.
https://us.msi.com/Motherboard/support/Z68MAED55_B3.html#down-driver&Win10 64
Follow the links accordingly and everything will be fine.
http://filehippo.com/download_winrar/64/69823/
Loyde Kessroy
Commendable
Apr 11, 2017
69
Okay, so after I got acces to internet and a usb, I downloaded an ethernet driver and a flash bio for my motherboard. The motherboard bio updated perfectly, but the ethernet driver is just sitting there as a file and it won't install or anything. What am I doing wrong? Nevermind, I found some kind of instal option in the file that I used to run it. Thank you.
