need help with lcd controller board
old_legend
149
So i Am Looking For Compatible LCD Controller Board For My LCD Its LTN154AT07 :??: From SAMSUNG TOSHIBA SATTELITE Laptop ....Any Help will BE Appreciated...😀
Yep that should do fine. Looks pretty much exactly the same as the one I bought as I too also use mine as a second second monitor and it works great. Looks about the same price as the one I bought as well.
The only thing I did my self on top of all this was to laser cut my self new surround to hold the display panel to make it look a bit more tidy. But yeah that controller will work fine with your LCD just remember to find your self a DC power supply that is the correct voltage and has the correct connector on it so that you can power your display. Thankfully my old laptop charger worked fine but yours might not fit but check and see if it will anyway before buying your self one to save your self some money.
Thanks man i never thought of PSU for Controller board ..i will search for it...can you please upload photos of your setup so i can get some ideas....
There's my setup if that helps its really simple. The controller board is usually taped to the underside of my desk my but I unstuck it all so you could see what was going on. It could be a lot neater/better but it works fine so I'm not too bothered about it. You could stick it all to the rear of your monitor instead but just do whatever works best for you. Mine's quite a bodge on the electronics side but meh it works haha. The surround for the LCD panel is just plywood that I have laser cut to shape then stuck together with double-sided tape of all things and then spray painted black to make it fit in a bit better with my desk and other monitor.
I only use that monitor more as a peripheral monitor for things like teamspeak or as a place to play a video full screen while browsing the net etc. :)
thanks man...:pt1cable:
