S sport93 Distinguished Dec 29, 2010 4 0 18,510 Oct 27, 2017 #1 hello guys i bought my computer from Barcelona (CATALAN) so my keyboard is stretched as CATALAN for example: key '8' if you press Shift it will give '*' and not '(' as it should, so how can i change that? thanx !
Solution viveknayyar007 Nov 2, 2017 sport93 : can someone help? Hello again Apologies for the late response. Can you please check the solution and other suggestions given here and see if any of them works for you? Good Luck!!
viveknayyar007 Splendid Apr 25, 2013 3,372 36 28,640 Oct 27, 2017 #2 Hello sport93 Can you please try the following: > Type Control Panel in the Cortana search box. > Click Control Panel from the list. > Click Change input methods from under the Clock, Language, and Region category. > In the next window, click Add a language. > Follow the on-screen instructions from there to add US Keyboard layout. Hope this helps. Cheers!! Upvote 0 Downvote
S sport93 Distinguished Dec 29, 2010 4 0 18,510 Oct 28, 2017 #3 hello Vive, i already did that but it seems like it wont change anything still the same layout Upvote 0 Downvote
viveknayyar007 Splendid Apr 25, 2013 3,372 36 28,640 Nov 2, 2017 Solution #5 sport93 : can someone help? Hello again Apologies for the late response. Can you please check the solution and other suggestions given here and see if any of them works for you? Good Luck!! Upvote 0 Downvote Solution
