Need help with motherboard
intasar93
Hello all,
Currently my specs are
AMD FX 6300
Gigabyte 78lmt-s2p
8gb RAM
GTX 750Ti
i was planning for a minor upgrade, not much
actually I'm getting a gtx 1050ti, and a SSD, So i would like to know which motherboard is a good one.
"I'm getting a gtx 1050ti, and a SSD, So i would like to know which motherboard is a good one." This doesn't make much sense. Your current board supports both of those. No need wasting money on a new motherboard for that old platform.
@bignastyid
Thank you very much for the suggestion, appreciate it. Actually my current mobo does not have a usb 3.0 slot plus it supports only 16gb ram, so i was a bit sceptical as should i upgrade or stay on the current mobo.
Currently Ryzen would be the way to go with a AM4 motherboard and 16Gb of DDR4.
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor ($199.99 @ Newegg)
Motherboard: Asus - TUF X470-PLUS GAMING ATX AM4 Motherboard ($132.09 @ Walmart)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($119.99 @ Newegg)
Total: $452.07
Generated by PCPartPicker 2019-01-20 18:41 EST-0500
However it depends on when you upgrade. If it's a few months away you should create a new thread and ask about the upgrade a week or so before you buy the parts.
