Need help with my first build V.1
Munakasvi
Commendable
Aug 2, 2016
27
I'm planning on building my first pc and I would appreciate it if you could give me your opinion
Intel Core i5-4690K (Boxed, LGA 1150 Haswell Refresh)
Western Digital Blue 1 TB (3,5" SATA 3.0)
ASUS DRW-24F1ST (DVD/RW)
AsRock B85M Pro4 (mATX, LGA 1150, DDR3)
Kingston HyperX Fury Black 2 x 8 GB (DDR3, 1866 MHz, CL10)
Microsoft Windows 10 Home (64-bit)
SilentiumPC Gladius M35 Pure Black GD-M35 (ATX)
EVGA SuperNOVA 650 G2 (80Plus Gold)
Gigabyte GeForce GTX 1070 G1 Gaming 8 GB
So for reference, I put together a partpicker for your proposed build and then what I'd recommend as a change. Prices are in US instead of Polish Zloty. Had to substitute a case that was available in the US for price comparisons but it's equal in terms of the exchange rate.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($235.99 @ B&H)
Motherboard: ASRock B85M Pro4 Micro ATX LGA1150 Motherboard ($73.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory ($73.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)...
Couple of things.... 1)4690k is overclockable and you pay big premium to get it overclockable, your motherboard doesn't allow overcooking. Switch to a 4690 (non k)and save a few buck or switch to a Z97 motherboard to allow over clocking.
2) really at this point in time haswell is kind of pointless you could build a 6600k/z170 motherboard/ddr4 memory build for the same money and get w bit better overall platform
Could you recommend a good fan for the 6600k?
Even a stock cooler that comes with the 4690k is fine if you aren't overclocking. That's the good thing about intel's. They run cooler than amd. If you have the budget, just run a small 120mm AIO watercooler. There are plenty out there for under $100. If you want to stay air cooling, a basic cooler like the Hyper 212 is fine. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
I moved away from air coolers personally but they are still good. That one is fairly inexpensive (29$) with very good ratings.
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card ($429.99 @ B&H)
Case: Rosewill CHALLENGER ATX Mid Tower Case ($24.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX US)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($17.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Total: $1088.10
Generated by PCPartPicker 2016-08-02 07:35 EDT-0400
Changing this out to a Skylake build that you can OC on
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($238.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($43.53 @ Amazon)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard ($98.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($71.88 @ OutletPC)
Total: $1157.62
Generated by PCPartPicker 2016-08-02 07:43 EDT-0400
Good cooler for a 6600k for light OCing or just better temps and noise levels would be a Cryorig H7, if you can find it in your market. Otherwise the easiest to find would be the Cooler Master Hyper 212 Evo.
