Stortebecker Aug 6, 2019 8 0 10 Sep 6, 2019 #1 Hello. This week i moved to Spain. I had no trouble connecting my pc components but my screen. Dont know if i need a voltage transformer (my screen electrical settings said 100v 1.5 a 50/60hz) even where to get one in Barcelona.
Solution Phillip Corcoran Sep 6, 2019 The MSI Optix MAG241C is compatible with power input range 100 -240 V @ 50/60Hz. In Spain the standard voltage is 230 V AC and the frequency is 50 Hz. An internal transformer converts AC to DC. The only requirement would be for a different plug-type to fit the wall-sockets in Spain, and there are adapters available for that. Can you explain in more detail what the actual problem is?
Phillip Corcoran Titan Moderator Sep 7, 2013 26,108 912 120,140 Sep 6, 2019 Solution #2 The MSI Optix MAG241C is compatible with power input range 100 -240 V @ 50/60Hz. In Spain the standard voltage is 230 V AC and the frequency is 50 Hz. An internal transformer converts AC to DC. The only requirement would be for a different plug-type to fit the wall-sockets in Spain, and there are adapters available for that. Can you explain in more detail what the actual problem is? Last edited: Sep 6, 2019 Upvote 0 Downvote Solution
Stortebecker Aug 6, 2019 8 0 10 Sep 6, 2019 #3 Uh thanks. Just the back of the screen said 100v so i thought i needed something else. Upvote 0 Downvote
