Question Need help with new build 2700 or 2700x
Echoceres
477
Please help me what processor/CPU cooler/case fans to get. I dont really mind if its not RGB i just want the best performing one.
Cant decide if 2700x or no x, I dont want to overclock and I will be using it for streaming. Price difference is almost 26$ from where Iam.
Heres the build list:
  • Processor : Ryzen 7 2700x or non x
  • Motherboard : MSI B450i Gaming Plus
  • Memory : Corsair Vengeance RGB Pro 16GB 3200mhz
  • Power Supply : Seasonic 520w M12II Evo
  • Graphics Card : Gtx 1060 3gb <- From my old build buying a 2060 in 2 months
  • SSD : Samsung 250GB EVO
  • HDD : 1 TB Toshiba
TCA_ChinChin
247
53
4,790
7
If one is not overclocking, then the 2700x would give you some more performance, since it will boost itself higher than the 2700. Could the a decent performance advantage, but can you afford the premium?
Echoceres
477
Yes I can. I think ill get it anyway. And sell the cooler for like 20 or so dollars.
Barty1884
The B450i is more than capable of handling even an overclocked 2700X so, provided you;'re comfortable with the premium, the 2700X would be the way to go.
In a day-to-day use-case, at stock, the gap isn't going to be particularly significant.
For gaming + streaming though, I'd suggest considering a Ryzen5 2600/2600X. In the US at least, a 2600 runs about 1/2 the price of a 2700X ($160 vs ~$300). That $100+ price difference would likely be better spent moving from a 2060 to a 2070....
Ultimately, 6c/12t of a Ryzen5 should still be plenty capable for gaming + streaming.
