Hi,
I am looking to build my first PC in a long time and need some help with the power cables going into the motherboard. Any help will be greatly appreciated.
I cant insert images to just added a link to each of them to hopefully explain what I am confused about easier.
Firstly I have an:
Asus AM5 ATX TUF GAMING X670E-PLUS
Be Quiet 1000w Dark Power 12 80+ Titanium
At the top of the motherboard I have 2x 8 pin connections labeled ATX_12V_1 & ATX_12V_2
IMG to mobo
My power supply has a MB(20 pin) and a MB(8 pin) which I am using for the main motherboard power socket.
I have occupied 2x PCIe slots to power my 7900xtx using the VGA cables provided(these split into 2 but I am only using 1 each)
IMG to Power Supply
I now have a P8 outlet on the power supply which terminates into the plug below:
Image to Plug
Do I use this plug in the top of the motherboard? Or do I use the PCIe on the power supply to VGA which by the looks will also plug in there?
If I use the P8 into the 2x 4pin which orientation do I use? Do I place them both in the same socket and have an entire 8 pin socket free on the motherboard, do I split them up so I have a 4 pin in each socket? This is where I am unsure.
Image to Instruction Manual
Thanks guys, looking forward to having a new pc.
Firstly I have an:
IMG to mobo
IMG to Power Supply
Image to Plug
