Need help with new Gaming PC Build. $2000
Last93z
24
8
10,515
Hello
I don't have much experience with PC builds so I would really appreciate it if you guys would help me out with which parts/specs to choose. As the title states, I'm looking for a new gaming PC and monitor only (144 or 165hz 27inch) that would last very long (4+ years maybe?) and would run everything at MAX FPS constant on ULTRA settings. I am going to dual-screen as well (will use old monitor as the 2nd one).
My budget is around 2000-2800 USD
Main games: WoW, CSGO, Witcher 3, Uncharted 4, Tomb Raider, Battlefront, The Division and a few more
Thanks and will be waiting for a reply 🙂
You can go for 4K monitor if you like. Here's a little list to choose from.
Amazing budget 4K monitor,
Samsung U28E590D 28.0" 60Hz ($339.99),
pcpp: http://pcpartpicker.com/product/L4nG3C/samsung-monitor-u28e590d
Outstanding 4K G-Sync monitors,
Acer XB280HK 28.0" 60Hz ($518.89),
pcpp: http://pcpartpicker.com/product/hTwqqs/acer-monitor-umpb0ee005
or
Acer XB271HK 27.0" 60Hz ($869.99),
pcpp: http://pcpartpicker.com/product/QZwqqs/acer-monitor-umhx1aa002
If you'd remove the initial monitor from my build suggestion and put the Acer XB271HK 27.0" 60Hz in (which has the same black & red theme as the initial monitor has), the base total would be $2824.21,
pcpp: http://pcpartpicker.com/list/g6NH4C
It's up to you to decide if you want a...
New build
Approximate Purchase Date: Within a week probably
Budget Range: $2000-2800
System Usage from Most to Least Important: gaming, watching movies, surfing the internet. all are important but gaming is mainly.
Are you buying a monitor: Yes
Parts to Upgrade: (e.g.: CPU, mobo, RAM) **Include Power Supply Make & Model If Re-using**
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Any is fine
Parts Preferences: Any
Overclocking: Maybe
SLI or Crossfire: no
Your Monitor Resolution: 1920 x 1080
Additional Comments: Main games: WoW, CSGO, Witcher 3, Uncharted 4, Tomb Raider, Battlefront, The Division and a few more.
And Most Importantly, Why Are You Upgrading: Don't have a gaming PC.
Since we now have more information about your preferences, here's a solid high-end gaming rig that also does great in a video rendering (color theme: black & red),
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($318.99 @ NCIX US)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler ($114.99 @ Newegg)
Motherboard: MSI Z170A GAMING PRO ATX LGA1151 Motherboard ($199.88 @ OutletPC)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory ($100.55 @ Amazon)
Storage: Samsung PM961 256GB M.2-2280 Solid State Drive ($156.29 @ Newegg)
Storage: Hitachi Deskstar 5K3000 3TB 3.5" 5400RPM Internal Hard Drive ($69.95 @ Amazon)
Video Card: MSI GeForce GTX 1080 8GB GAMING X 8G Video Card ($664.35 @ B&H)
Case: Corsair 760T Black ATX Full Tower Case ($159.99 @ Amazon)
Power Supply: SeaSonic 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($98.99 @ My Choice Software)
Monitor: Acer XB241H bmipr 24.0" 144Hz Monitor ($370.36 @ Amazon)
Total: $2344.33
Generated by PCPartPicker 2016-10-30 14:47 EDT-0400
Description too.
CPU
Went with the best LGA1151 socket CPU Intel is currently offering, a Skylake family i7-6700K.
CPU cooler
Put in the best AIO water cooler there is. Only the custom made water cooling loop is better than the Kraken.
MoBo
Went with the MSI Z-series MoBo that has controllable RGB LED lights for eyecandy. MoBo's main feature is the ability to OC (overclock) the K-series CPUs and it also supports faster RAM speeds than the stock 2133 Mhz. Since MoBo has LGA1151 CPU socket, it supports current Skylake and future Kaby Lake and Cannonlake CPUs from Intel. For additional info about MoBo, here's a link,
specs: https://www.msi.com/Motherboard/Z170A-GAMING-PRO.html#hero-overview
RAM
Went with the 2x 8GB of RAM at speeds of 3000 Mhz. RAM sticks have red LEDs to match the theme of this build.
Storage
Went with an ultra fast M.2 NVMe SSD for as an OS drive. M.2 SSD is about 6 to 10 times faster than regular 2.5" SSD.
Also added reliable Hitachi 3TB HDD for storage.
GPU
Put in MSI GTX 1080 that is currently 2nd best GPU in the world (the best being Titan X Pascal with a price tag of $1200). GPU also shares the black & red theme i went with this build.
Case
Since case is more of a personal choice, i don't know if you like the one i picked out. It's full-tower ATX case and it's entire side is one big window. It also has very easy access to the case internals and it's front LED fans are a nice match to the black & red theme this build has.
PSU
Your systems power plant comes directly from the best PSU OEM, Seasonic. Fully-modular for making the installation very easy and 80+ Gold standard for efficiency.
OS
Regular Win 10 Pro 64-bit, not much to say about it.
Monitor
Picked a 24", 144 Hz, 1ms monitor for you. This monitor supports the G-Sync, making your gaming even better. Monitor also shares the black & red theme of this build.
"Nvidia G-sync is groundbreaking new display technology that delivers the smoothest and fastest gaming experience ever. G-Sync's revolutionary performance is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag."
Edit:
If you want to have 27" monitor then here's one of the cheaper ones that supports the G-Sync, Acer XB270H Abprz,
pcpp: http://pcpartpicker.com/product/wzKhP6/acer-monitor-umhb0aaa01
What a nice reply. thanks for putting time into this and the detailed info, nice description as well
what do u think of 4k monitors? arent they around the same price of the ones you mentioned? and if so, shouldnt I go for it?
or
It's up to you to decide if you want a matching monitor and PC set or go with a cheaper Acer XB280HK 28.0" 60Hz monitor and pocket the rest.
As far as my personal opinion goes, i'm too old school to answer if you should go for 4K or not. I'm happy with 1024x768 resolution. 😀
That being said, i'd go with the initial 24" monitor i picked and save the rest for something else.
