Need Help with New Pc
Drizzit101
Hey guys,
Need some assistance regarding a new I got a few days ago. I've never overclocked a/my system before and I'm worried about Auto voltage left on my system randomly going from 0.700 to 1.100. I just want it to be stock set amount and worry about overclocking it a few years on.
Intel® Core™i7 Six Core Processor i7-5930K (3.5GHz) 15MB Cache
ASUS® X99-A: ATX, HSW-E CPU, USB 3.0, SATA 6 GB/s
16GB Corsair Vengeance DDR4 3000MHz X.M.P (4 x 4GB)
Idle temps for CPU: 34-37c
For GPU: 30c
For motherboard:28c
This is my system specs and I have no idea what i'm touching in the bios. I looked a lot of stuff up and there isn't just one Voltage for the cpu to tweak there's so many.
I appreciate you taking the time to read and if you do so reply I will be grateful.
P.S to note the pc was pre-built with 6 fans, 2 front, 1 back, 2 top and 1 on CPU Noctua NH-D15S.
You can set up voltage in your bios, but auto voltage is okay, it takes as much power as it needs, but won't overvoltage your cpu, I would let it as it is 😉
