Need help with no signal
Cori__
8
So I asked here before and I switched out the RAM to make it compatible but still no signal on my buddies computer. I've built many computers before for myself and I have never ran into this issue. No BIOS splash screen no nothing........... Any help would be greatly appreciated......
2 x SAPPHIRE NITRO Radeon R9 390 DirectX 12 100382NTOC-2L 8GB 512-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready Tri-X OC ...
AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+ 220W FD9590FHHKWOF Desktop Processor - Black Edition
Write Review
1 x AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+ 220W FD9590FHHKWOF Desktop Processor - Black Edition
MSI MSI Gaming 990FXA-GAMING AM3+/ AM3 AMD 990FX & SB950 SATA 6Gb/s 2 x USB 3.1 ATX AMD Motherboard
Write Review
1 x MSI MSI Gaming 990FXA-GAMING AM3+/ AM3 AMD 990FX & SB950 SATA 6Gb/s 2 x USB 3.1 ATX AMD Motherboard
G.SKILL TridentX Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C10D-16GTX
Write Review
1 x HyperX FURY 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model HX316C10FK2/16
LG 25UM56-P Black 25" IPS 2 x HDMI FHD ULTRAWIDE LED Monitor 250 cd/m2 5,000,000:1
Write Review
1 x LG 25UM56-P Black 25" IPS 2 x HDMI FHD ULTRAWIDE LED Monitor 250 cd/m2 5,000,000:1
Seagate Hybrid Drive ST1000DX001 1TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop SSHD
Write Review
2 x Seagate Hybrid Drive ST1000DX001 1TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop SSHD
This is the wrong memory for your setup. I recommend removing it.
AMD FX-9590 requires Liquid CPU Cooling on that motherboard.
POWER REQUIREMENTS for 2 Radeon 390's is 1000 watt minimum.
I would try using just one for starters. 750 watt power minimum.
Buddy, no offence but I updated the RAM that is compatible. I said it in the specs above. And I am only running 1 GPU. The CPU has a good enough Heat Sink.
