raise the clock ratio to 20.0, and make sure that the cpu is unlocked, and raise the voltage by ~0.025v, and boot. run prime95 for a couple hours, and if no errors, you have a stable 4.0 ghz 😛
i would try 1.35 first, if unstable add 0.1v until its stable, and dont go above 1.425v at that speed.
Ok, currently testing, i set my voltage 1.35 . Everything seems ok. When voltage was on auto, sensors sometimes showed over 1.4 voltage. Now it shows 1.32 all the time. running on 3.92ghz 99% . Also temps are lower
