[SOLVED] Need help with PC build
Apr 22, 2020
Budget Range: $1,200-1,700
PC usage: rendering in DAZ3D studio iray, general use, graphic design (Photoshop, Illustrator), and watching movies (digital and dvd)
Monitor: using my current monitor
(Asus 23’’ widescreen LED monitor)
Keyboard and Mouse: using my current keyboard and mouse
Operating System for new PC: Windows 10 Pro
Hi, I need help building a PC that I can render complex 3d scenes in DAZ Studio 4.12 that won’t slow down my PC, the PC will also be used for general use and Photoshop. I don’t have a problem waiting for complex scenes to render in 1-2 hours as long as I can use the PC for other things while DAZ Studio is rendering in the background. Thank you
MY OLD PC SPECS 2014:
(Please let me know if there is any parts of my old PC that can be used for my new build.)
CPU: Intel Core i7-4770K Haswell Quad-Core 3.5 GHz LGA 1150 84W
Motherboard: GIGABYTE GA-Z87-DS3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
GPU: MSI GeForce GTX 650 Ti DirectX 11 N650TI-1GD5/V1 1GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
RAM: Ballistix Sport 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
HDD: WD Black 1TB Performance Desktop Hard Disk Drive
Case: Corsair Carbide Series 200R Black Steel / Plastic Compact ATX Mid Tower Case
PSU:
SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
Monitor: Asus 23’’ widescreen LED monitor
OS: Windows 7 Professional SP1 64-bit
DVD Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
I have put this list together for you and you can do many many things with it at one time. Assuming you don't need a monitor.
PC Parts
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($294.14 @ Amazon)
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler ($129.99 @ NZXT)
Motherboard: ASRock X570 Extreme4 WiFi ax ATX AM4 Motherboard ($224.99 @ Newegg)
Memory: Corsair Vengeance LPX 32 GB (4 x 8 GB) DDR4-3200 Memory ($167.99 @ Newegg)
Storage: Team GX2 512 GB 2.5" Solid State Drive ($55.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($50.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB WINDFORCE OC Video Card ($399.99 @ Newegg)
Case: Deepcool MATREXX 50 ATX Mid...
PC Parts
Case: Deepcool MATREXX 50 ATX Mid Tower Case ($57.98 @ Newegg)
Power Supply: Corsair CXM V2 (2017) 750 W 80+ Bronze Certified Semi-modular ATX Power Supply ($103.98 @ Newegg)
Total: $1486.04
PC Parts
Total: $1486.04
would like to know is this a good build:
PCPartPicker Part List: https://pcpartpicker.com/list/HPv3Mc
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card
Case: Deepcool MATREXX 50 ADD-RGB 4F ATX Mid Tower Case
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM 64-bit
Motherboard: don't have a lot of knowledge about choosing the right motherboard so i was wondering if any of these motherboards work for this build
Asus PRIME X570-P ATX AM4 Motherboard https://pcpartpicker.com/product/McfFf7/asus-prime-x570-p-atx-am4-motherboard-prime-x570-p
Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard https://pcpartpicker.com/product/dm...tx-am4-motherboard-tuf-gaming-x570-plus-wi-fi
MSI MPG X570 GAMING PLUS ATX AM4 Motherboard https://pcpartpicker.com/product/q4...plus-atx-am4-motherboard-mpg-x570-gaming-plus
MSI B450 Gaming Plus MAX ATX AM4 Motherboard https://pcpartpicker.com/product/BH...-max-atx-am4-motherboard-b450-gaming-plus-max
