[SOLVED] Need Help With Pc
23
i recently got a xeon e3-1230 v5 mid tower server that has a 290w PSU i also got a evga gtx 750 ti.tho it is reccommened to have a 300w PSU.i saw people online running it on PSUS with less then 290w.when i plug in the gpu the pc starts up but the fans start spinning really fast and nothing shows up in the display.i tried this twice and only let it run for 15-20 sec cuz im not rly geeky in pcs and was scared by how fast the fans were spinning.should i keep it running,or is this a bad sign?and i should consider buying a PSU.also there was a flashing yellow light both times after i powered it down.
Digging through some Dell Forums, it seems others have asked similar questions. Dell "officially" only supports GPUs when they are used for compute (not display) functions.
One forum entry indicated a user with a GT730 that worked fine, but caused system fan speeds to get quite fast and loud. Sounds similar to what you mentioned.
For example:
https://www.dell.com/community/PowerEdge-Hardware-General/PowerEdge-T130-high-fan-speed-after-installing-graphic-card/td-p/5054518
https://www.dell.com/community/PowerEdge-Hardware-General/GPU-support/m-p/5081489#M50175
See here for tips by an actual user. You may need a lower powered GPU to get it to work properly.
http://vcojot.blogspot.com/2016/11/some-tips-about-running-dell-poweredge.html
very late update but i managed to get everything working the pc was not detecting the gpu as a video controller so when i plugged in the vga to the port in the motherboard i got a display and then i booted up into windows and installed nvidia drivers and everything worked great!
Latest posts
