Hi and thank you for reading my post.
I have a hp dc7100sff that i have upgraded before and I am upgrading it again. The stats are as follows
Video: ATI Radeon 4350, 512 mb vram
Processor: P4 3.8 ghz ht (intel 670)
Ram: 4gig High density
Drives: 1 80 gig MDT MD800jD-00MSA1, 1 40 gig WDC WD400BD-75MRA1, NEC dvdrw ND-3450A
Operating system: Lubuntu 64bit 11.04 Natty Narwhal
Power supply: 240 watt
I am adding a 3.0 usb card that has only 1 usb port and is a pci card. Another card that is a compact flash card adapter that holds 4 cf cards and it has raid abilities that is also pci will also be added. Neither of these need a power source other than the pci slot. The compact flash cards will be used as swap space in linux (faster than hd space) so they are only 1 gig each.
Will the 240 watt power supply be good enough? if not what are my options here? If you can please post links.
Thanks in advance
Thanks in advance
