I want to ask about PSU Fortron FSP400-60APN 400W (85PLUS), can it handle 9800GT 512mb GDDR3 256bit from Sparkle , i dont buy anything yet, but i will soon. I want to know do this PSU have 6pin x2 connectors.
Is it a normal 9800GT? if yes, then like the other have said above, you will need6pin power connector.
If it green edition then you don't need additional power from PSU.
Anyway, both version is okay for that PSU.
OK i will not make a new topic but can sameon tell me please which one is better HD 5670 512mb GDDR5 128bit from XFX or 9800GT 512mb GDDR3 256bit from Sparkle?
I'm a user of the BFGtech plus 80 psu, I'm sure if you go here you'll find the psu your looking for as well as the 2 6-pin connectors your looking for 38a power supply. Read the details and it tells you what connectors are supplied. One more thing be sure it is supported for your PC case.
So that means 9800GT is better? Couse in some websites ppl says the 9800GT runs slower then HD 5670
If the 9800GT has a power connector then it is slightly faster but the HD5670 is DX11 compatible and uses much less power. If the 9800GT lacks a power connector then they should be equal in performance
