Need help with RAM replacement
plucky
My Samsung np-s3510-a03uk was recently diagnosed with a faulty RAM chip, so I am now running on 2GB instead of 4GB, which is fine for the most part except when I run certain programs.
My problem is, I have no expertise in this area, but I have two similar RAM chips and I am wondering if I can use them as a replacement for the faulty chip.
The faulty chip is a Samsung 2gb 1rx8 pc3-10600s-9-10-zzz. There is another code which I think is the serial number: m471b5773chs-ch9.
Can I replace with either of the following:
Samsung 2gb - 1rx8 pc3-10600s-09-11-b2 (S/N: m471b5773dh0-ch9)
or
Samsung 2gb - 2rx8 pc3 - 8500s-07-10-f2 (S/N: m471b5673fh0-cf8)
Excuse my ignorance, hope you can help!
Thanks for the reply!
I guess my question is, are all pc3-10600s chips the same?
The faulty chip and one of the replacements have almost the same name apart from the last couple of numbers.
Can I just install one to replace the other?
