[SOLVED] Need help with receiver and monitor speakers
Kirill Steshin
11
Hi,
Got Mackie's MR5, and Yamaha HTR-6250.
I can not figure how to connected than - other than plug speakers into a front 1\4 jack.
Problems are:
A) Have to plug via a split-Y cable, which is an issue 'cause
B) It hissing - and it's REALLY annoying.
Using receiver to get HDMI video and audio from PC, PS3 and PS4 to one TV, with HDMI channels being switch.
Those are powered speakers, you connect them directly to the source not to a receiver.
If the receiver has a Line Out set of jacks use that.
I would get non-powered speakers to use with the receiver, you should use the right thing for the job.
