Hello. I have received great help from this community in the past and am hoping that the tradition will continue.
I recently purchased a Samsung Q430 back around July or August. The specs are as follows: Intel i5 Core Processor, 4 GB DDR3 RAM, and Nvidia GeForce 310M graphics adapter. A couple of days ago it started to hang. It doesn't completely lock up the system, but it has slowed to an excruciating crawl. It's very difficult and frustrating to use the computer in its current condition.
I am usually fairly knowledgeable about computers, but this one has me stumped. I am experiencing sporadic shutdowns along with slow operating system performance. I am running Windows 7 Professional x64. The machine came with Windows 7 Home Premium x64, but I upgraded as soon as I got the laptop. But that was months ago. Every now and again the system runs fine. Yesterday I completely reinstalled all drivers and have the same problem. I have restored Windows to different points before I started having problems. No luck there either. I use Avast Antivirus and have run a virus scan using both that and Microsoft Security Essentials. Neither check has turned up a virus. I used Malwarebytes Anti-Malware and found no malware either. I have the same problem when I boot up into Safe Mode, so I can eliminate the graphics driver.
Event viewer shows the following stats for the last week: 13 Critical errors, 430 Errors, and 98 Warnings. The most common error I see in the log in Service Control Manager, and the most common critical error I see is Kernel-Power. I suspect the critical errors are from the system failing resulting in BSOD, so that doesn't help me much. And I've looked up several of the Error IDs on Microsoft's Knowledge Database but it didn't help me out either with the troubleshooting.
At this point, I'm looking for help pinpointing whether or not I have a hardware issue or a software issue with Windows 7. The laptop is only a few months old, so I suspect that hardware is not at fault, but can't be completely sure. The laptop doesn't feel like its overheating either.
As I write this on my desktop computer, my laptop just received a BSOD on iastor.sys. Hopefully this helps. Please let me know what other info you guys need if I have left anything out.
Thanks in advance,
Adam
Thanks in advance,
Adam
