As of yesterday, I removed the keys from my keyboard and cleaned out the underneath since the keyboard is LED backlit. It went flawlessly, except for removing the space bar. I tried removing it carefully, but I only removed the spring-like bar from underneath, and now they key is loud when pressed and it's slow. Being that this is my first time removing keys, I don't understand how to detach the key from the stabilizers. I looked online and found my keyboard isn't mechanical, so I have no clue in the slightest how to remove it (since most tutorials show you how to remove mechanical space bars). I've been trying to put the bar back into the space bar but to no avail. If someone would get back to me within the day I would heavily appreciate it.
Thank you!
Keyboard: Blackweb Centaur BWA15HO108
Thank you!
