I use Sync Toy to do nightly back ups of my PCs. 3 PCs total. 2 x Win11 and 1 x Win10. all 3 Enterprise edition. Theyre all set up to run in the middle of the night using task scheduler.
One of my windows 11 machines isnt running Sync Toy via task scheduler and I cant figure out why. Task scheduler is set up exactly the same on all 3 PCs with the exception of the user account it is set to run with is obviously set to the user account on that specific machine. That user account is part of the administrators group just like it is on my other two PCs. Sync Toy runs outside of task scheduler fine. Task scheduler says it starts running the task but it only runs for literally 1 second and then its supposedly done. There has to be something different in Windows itself Im guessing but if thats the problem I dont know where to look that I haven't looked already.
Heres an export of the task scheduler entry if you want to see it but it works on the other two machines so I highly doubt theres anything wrong with the task itself.
System specs:
CPU: AMD Ryzen 9 5900X
CPU cooler: Phanteks Glacier One 240MP D-RGB AIO
Motherboard: GIGABYTE X570S AORUS MASTER
Ram: G.SKILL Ripjaws V Series 32GB (2 x 16GB)
SSD/HDD: OS drives are WD BLACK SN850 NVMe M.2 2280 500GB PCI-E 4.0 x4 run in Raid 1 + various SSDs/HDDs for storage.
GPU: GIGABYTE RTX 3080 Ti
PSU: CORSAIR GS800 800 W
PSU Purchase Date: 8-10 years ago?
Chassis: LIAN LI LANCOOL II MESH RGB BLACK Tempered Glass ATX Case
OS: Windows 10 Enterprise Ed.
Monitor 1: ASUS TUF Gaming 27" 1440P Monitor (VG27AQL1A) - QHD (2560 x 1440), IPS, 1ms, 170Hz
Monitor 2: BenQ 27" VA LCD Monitor 4ms (GTG) 1920 x 1080 GW2750HM
Monitor 3: SAMSUNG 24" LCD Monitor 5ms (GTG) 1920 x 1080 S24A460B-1
Monitor 4: Same as #3
System specs:
