[SOLVED] Need help with the front panel -+ connectors
The pwr and rst switches are not polarity sensitive.
They are momentary contact switches.
You can connect them any way.
The led leads for HDD and cpu ARE polarity sensitive.
The black/white common colored wire is ground and and the colored wire is +
If you get it backwards, the led will not light, but no harm is done, just reverse them.
