Need help with upgrades for old computer
well until no so long I was working in my office with a similar machine, there are a few things you can do;
this is your system; (taken from link)
Operating System
Windows 7 Home Premium 64-bit SP1
CPU Intel Core 2 Duo E7500 @ 2.93GHz: Wolfdale 45nm Technology
RAM 4.00GB Dual-Channel DDR3 @ 531MHz (7-7-7-20)
Motherboard Dell Inc. 018D1Y (CPU 1):  45 °C
Graphics DELL ST2210 (1920x1080@60Hz)
Intel G45/G43 Express Chipset (Dell)
Storage 931GB Seagate ST1000DM003-1ER162 ATA Device (SATA): 35 °C
Optical Drives PLDS DVD+-RW DH-16AAS ATA Device
Audio High Definition Audio Device
Looks like you own a Dell Inspiron 500 Series probably a Dell Inspiron 560 MT or 560S ??
According to sources on the internet while looking for your Dell...
One upgrade that is rather standalone would be upgrading your ram, 4gb won't cut it for most games anymore and if you're wanting a work station more multi-tasking power is good. Coupled with that fact that DDR3 ram is dirt cheap now because of DDR4 popularity. You could go for a 8gb kit or even 16gb. That said most other upgrades besides a new graphics card require multiple components to be switched out. If you want to change the processor you'll most likely need to change the mother board as well - vis versa. Keeping all that in mind I would say although it's not technically cheaper it will serve you better in the long run to get a new computer or even better build one yourself (which most people would recommend). It's very easy to get a budget PC that handles quite well for around $550. I'm not sure what your budget is but if you can afford I'd invest in a new setup. Dumping money into a system that is out-dated all around seems counter intuitive.
Operating System
According to sources on the internet while looking for your Dell Motherboard model no.018D1Y
- I found that it could be pushed to 4 x 240-pin DDR3 DIMM slots – Dual Channel DDR3 1333/1066 MHz non-ECC, un-buffered memory (Max 8GB)
- The Video PCIE slot is a 1 x PCIe 2.0 x16. which in itself should not be an issue because more recent v3.0 should be backwards compatible, but if a video card doesn't work on it, could be a bios or incompatibility.
- CPU supported on a LGA775 Die would be Support Intel Core 2 Quad, Core 2 Duo, Pentium Dual Core.
- Designed by Dell inc. 018D1Y to Support Operating Systems: Win 7/8, Vista/XP
- power supply that comes standard with the 500 series is 320w (important when picking a new video card)
Considering 8gb of DDR3 4x2gb will cost about 65$, say a GTX 1050TI/RX470 will run you in about 130$
those are basic upgrade you can do, now when it comes to upgrading the cpu (not that I was able to narrow exactly which dual core 2 quad it allowed yet,. but assuming best possible scenario a Q9560, that runs, used, 100-150$ easy.
a new cpu fan 30$ and your done... so total 65$+130$+150$ = 345$ no including taxes rebates etc.
you could upgrade the system to a brand new G4560+ Mobo +Ram + video card for ; 305$ and be in this millennium.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor ($59.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard ($69.89 @ OutletPC)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory ($55.39 @ OutletPC)
Video Card: PNY GeForce GTX 1050 Ti 4GB Video Card ($119.99 @ Amazon)
Total: $305.26
Generated by PCPartPicker 2017-03-31 07:48 EDT-0400
