Need Help With Watercooled GPU!
Jackaboy442
20
My GPU (r9 390) will not send a video signal and I think it may have died. It is water cooled by an Aplhacool GPX A-390 M02 (For MSI r9 390 gaming 8g). I had one leak while I was water cooling, but the leak was on the 90 degree fitting on the GPU, but it leaked down where i caught the leak with paper towels and fixed the leak. The GPU was above where the leak was. I followed the directions for the cooler installation, and when I turned on the PC, there was no video signal. My cpu works (fx-8350 water cooled by XSPC Raystorm), and I can turn the PC on. I just need help with the GPU. I really need help with this, and I will be VERY greatful if you can help me. Thanks.
Yes I did, if the card dosen't work, should I get a new one? if so, Im just going to stay away form custom cooling and use a premade corsair h110 i.
Ok, just had to ask. I've heard of people not doing it which wouldn't make sense.
As far as that goes, I couldn't say. It may very well be dead.
Do you have a different GPU to try in there to make sure it's not the system?
I have future plans myself to get a AIO for the GPU. It seems pretty cool and really efficient in contrast to the air cooling solutions in them.
I do not have another GPU to test, which kind of stinks, thanks for the help, I'll probably just return the watercooling stuff and buy a new GPU. Thank you SOOOOOO much for the help.
I'll probably just get a hybrid gtx 1070, but thanks for the help =)
