[SOLVED] Need help
Jul 22, 2019
9
Im doing this for my friend.
Couple months ago he bought used PC because his pc was on last legs.
He saw after few days there is some problems with it but he updated drivers , windows , and so on and it was fine.
Past few days he is getting screen freez with pixels all over the place and after 15 seconds his PC restarts and when boots up his resolution is all wierd.
And this problems only happens while he is gamming.
We cant find a solution , we dont know if its GPU , Motherboard , RAM , Screen but we do have some pictures and maybe you guys can tell us whats going on , because he was thinking to buy new GPU anyway and if its GPU problem then it would be amazing.
These are the pictures of his screen when it happens and i added his specs.
View: https://imgur.com/uGJkbrV
View: https://imgur.com/tRlXWga
View: https://imgur.com/fys6DEP
View: https://imgur.com/QkhQyQ7
- how screen looks after the reboots
View: https://imgur.com/a4Gl91u
- his spec
Jul 22, 2019
9
Artifacts, lines, discoloration are signs of a dying GPU. He should replace it.
What is the make, model and age of his GPU?
he said 7 to 8 years for sure he just wants few people to say what he thinks allrdy and its that , that GPU is on its last legs :)
