Question need help
May 5, 2023
i am upgrading my gpu to a 3070 and i am not sure if a GIGABYTE GeForce RTX 3070 will be compatible with my motherboard, asus prime H310M-E R2.0.
any help would be greatly appreciated
That and the case clearance.
What is your full system specifications?
okay i figured out that my psu is too weak so im upgrading that aswell, im not sure how i can share my pc spec with you easily but i have digital storm lynx tower from 2019 Chassis Model: Digital Storm Lynx - Level 2 (MPN-9700F-1650) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7-9700F (4.7 GHz Turbo) (8-Core) 3.0 GHz (Not Overclockable) Motherboard: ASUS / MSI / ASRock (Intel Chipset) (Up to 2x PCI-E Devices) System Memory: 8GB DDR4 Digital Storm Performance Series Power Supply: 600W Digital Storm Performance Series (Supports up to an NVIDIA RTX 2070 GPU) Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD (240GB Digital Storm Performance Series) Storage Set 2: 1x Storage (2TB Seagate / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1650 4GB Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: AIR: Stage 1: High-Performance Copper Heat Pipe Cooler HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Digital Storm Performance Series (RGB Fans) Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stock Factory Turbo Boost Advanced Automatic Overclocking Graphics Boost: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Operating System: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean Install) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10)
