X xl2aNd0m Honorable Dec 13, 2012 101 0 10,690 Mar 5, 2017 #1 Hello, I just finished my build. Case is the corsair 570x and my mobo is a Asus z270 AR. I need recommendations for LED strips that are Aura compatible. Nothing too ridiculous just enough to light the inside a bit.
Solution mcnumpty23 Mar 5, 2017 i highly recommend phanteks led strips they are about the best i have seen great colour from them magnetic thickest rubber coating i have seen on a led strip to protect them from bumps,scrapes etc and can get an aura adapter for them https://www.overclockers.co.uk/phanteks-magnetic-rgb-led-strip-400mm-cm-024-pt.html and aura adapter https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Mar 5, 2017 Solution #2 i highly recommend phanteks led strips they are about the best i have seen great colour from them magnetic thickest rubber coating i have seen on a led strip to protect them from bumps,scrapes etc and can get an aura adapter for them https://www.overclockers.co.uk/phanteks-magnetic-rgb-led-strip-400mm-cm-024-pt.html and aura adapter https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html Upvote 0 Downvote Solution
