[SOLVED] Need little help about ata-100 to usb
16
Hello, trying to help my friend but do be sure I want ask here also if I get this right.
Baisically my friend have his old laptop HDD (laptop not working) and he need the files. So I was looking that there is possible to transfer files with usb and HDD connector to another laptop.
He have pretty old HDD so its bit confusing.
HDD photo: View: https://imgur.com/a/NC7828f
As I can understand this is HM100JC and there is some link about that I guess: https://www.hdsentinel.com/storageinfo_details.php?lang=en&model=SAMSUNG HM100JC (i think its same)
and as I can read its supports: Ultra-ATA/100 (am i correct?)
And only adapter I found was https://www.ebay.com/itm/3-5-IDE-to...684519?hash=item2381a14267:g:-Z8AAOSwUP5a1v8p but im not sure is this correct or is there any another adapter?
Just want to ask to be sure :)
[/QUOTE]
That is adapter fot 3.5" PATA drives.
You need this type of adapter (for laptop drives):
https://www.wantitall.co.za/pchardw...ata-hdd-hard-disk-drive-ssd-to-a-__b06vvz41j5
Thanks for answer.
So I found this, https://www.amazon.com/QNINE-Laptop-Adapter-Convert-Parallel/dp/B01MU023LO/ref=sr_1_1?keywords=QNINE+2.5"+Inch+IDE+to+SATA+Adapter,+Convert+Laptop+44+Pin+Male+IDE+PATA+HDD+Hard+Disk+Drive+SSD+to+a+Serial+ATA+Port&qid=1573474334&s=electronics&sr=1-1
Its same as I can understand but now I also need cables to connect this with another laptop right? If I can understand this adepter what you give me support 2,5 so I need 2,5 adapter also?
Thanks for the answer.
But can I understand it correctly now.
I connect old HDD with this adapter what link you gived me and that i connect the adapter with SATA to USB connector and I put the USB in my laptop and I can see the old HDD files right?
I found this USB to SATA I guess its correct: https://www.amazon.de/dp/B07F7WDZGT...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== ?
Thanks for answer.
[/QUOTE]
But what powers the SATA drive? Is USB enough?
