D Dreadblood86 Honorable May 5, 2017 44 1 10,535 Jun 30, 2020 #1 can anyone help me find a motherboard with a 3 pin rgb connector for the i7-4790K
Solution GarrettL Jun 30, 2020 Well, if it’s an LED 3 pin cable for aRGB it needs 5 volts and it is a similar looking header as the 4 pin but on pin is blocked out. A 4 pin LED RGB header is 12 volts.
GarrettL Distinguished Dec 4, 2019 2,414 640 19,990 Jun 30, 2020 #2 That might be a tough find. What are you trying to do? It would likely be cheaper to use a lighting node. The pc RGB world is a mess as there is no industry standard, as of yet. Upvote 0 Downvote
abvolt Feb 17, 2020 27 7 35 Jun 30, 2020 #3 3 or 4 pin will all work in the same hearder does not matter. Upvote 0 Downvote
GarrettL Distinguished Dec 4, 2019 2,414 640 19,990 Jun 30, 2020 Solution #4 Well, if it’s an LED 3 pin cable for aRGB it needs 5 volts and it is a similar looking header as the 4 pin but on pin is blocked out. A 4 pin LED RGB header is 12 volts. Upvote 0 Downvote Solution
CountMike Titan Oct 31, 2015 35,669 3,835 147,990 Jul 1, 2020 #5 I don't think ARGB was invented back then. Upvote 0 Downvote
