[SOLVED] Need new fans for my NZXT H440 Case
michael Q
59
So i've never replaced fans before and im feeling at a loss on what fans are "compatable" with my case, i know the back fan is 140mm and the front 3 are 120mm and that the h440 came with a fan hub i just want to double check that the fan hub oly accepts 3 pin connections for any new fans that i buy?
All normal fans today are 3 pin (only the really old ones are 4 pin power connector to psu.... there are others but today standard is 3 pin).
I would recommend arctic cooling if you're on budget.
