After doing tons of research and getting help from people in the forums here at TH I have narrowed my choices down to two, with minor but I deem significant differences. I am still open to opinions/suggestions as I have not bought anything yet.
Build 1:
CPU and Motherboard:
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
$369.98
HSF:
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
$29.99
CD ROM:
Samsung 22x
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151192
$19.99
Monitor:
ASUS VH236H Black 23" 2ms(GTG) HDMI Widescreen Full HD 1080P LCD Monitor 300 cd/m2 20000 :1 (ASCR) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
$199.99
Case/PSU:
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
$194.90
OS:
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
$99.99
GPU/RAM:
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3OB1600LV4GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227495
ASUS EAH5850 DirectCU TOP/2DIS/1GD5 Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121370
$423.98
HDD:
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
$54.99
SSD:
Kingston SSDNow V Series SNV425-S2/64GB 2.5" 64GB SATA II Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139132
$137.99
TOTAL: $1531.80
Build 2:
All the same components as the last build but the following will be different:
GPU:
XFX HD-587X-ZNFC Radeon HD 5870 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150476
$399.99
RAM:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
$109.99
HDD:
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
$79.99
SSD:
NONE
TOTAL: $1504.81
I have a 1TB WD Caviar Green drive I have from an external enclosure that I will be throwing into the case as well for added storage.
If you could please look over and suggest which one is a better "bang for the buck" that would be greatly appreciated. Like I said, there are a few but major differences in the build such as RAM and GPU and HDD/SSD.
Also, I am open for suggestions for replacement parts or a total new build along the same guidelines as these above. I am not trying to spend more than $1500-1600.
Thanks in advanced,
Derrick
Build 1:
$369.98
HSF:
$29.99
CD ROM:
Samsung 22x
$19.99
Monitor:
$199.99
Case/PSU:
$194.90
OS:
$99.99
GPU/RAM:
$423.98
HDD:
$54.99
SSD:
$137.99
TOTAL: $1531.80
Build 2:
GPU:
$399.99
RAM:
$109.99
HDD:
$79.99
SSD:
NONE
TOTAL: $1504.81
Thanks in advanced,
Derrick
