[SOLVED] Need opinions regarding my first ever budget build
Nov 8, 2020
12
Budget 500 euros ( Valorant, csgo, Warzone, Metro exodus, GTAV ... Programming (mostly 1080p gaming) )
i planned to have the ryzen 3 3300x (131€) but it has been out of stock. which leads me a couple weird options :
ram : 8*2 3200mhz Gskill (54€)
storage : 500GB ssd (44€)
PSU: 450 80+ bronze (40€)
now here i have these combos for cpu+gpu+motherboard that i need help with :
1/-3100 (OC intentions) (95€) + B550M asrock pro4 (100€) + palit gtx 1650S (152€)
2/- 2600x (129€) + B450M asrock pro4(70€) + palit gtx 1650S
3/- 3100 (OC) + B450M asrock pro4 + palit gtx 1660 (178€)
PS(original combo was 3300x+ gtx 1650s+ b450)
another PS(upgradability is why i slapped the 550M in there)
any opinions on what's best ? should i wait for 3300x to be back in stock ? anywhere else i could invest the money in ?
i have done some research and this one stood out "
Thermaltake TR2 S 700W
recommended ?
No. If you want to select your own use this list and choose from tier A or B for good models but do not go below tier C.
Most important part of the build is the power supply. What's the brand and model of the power supply you intend to use? 40€ is about $48 USD and I don't know of any models in that price range worth buying.
i was planning to get the corsair CV450 450w (if its notgood enough then suggestions ?)
That power supply is for a home office computer. It's not made for the demands of a gaming system. You need to get something better than that. If you want a Corsair model do not go any lower than the 'CX' series.
recommended ?
recommended ?
TR2 is tier 7 on this list:
You can do better.
A psu is a long term investment.
Look for a tier 1/2 unit, no less than 3.
Can you buy a i3-10100 for your budget.
It is a very good gaming competitior to the 3300x
https://www.techpowerup.com/review/intel-core-i3-10100/15.html
Gigabyte G750H (750w for 60 euros and should be on A tier if i am correct)
You can do better.
Gigabyte G750H
Yes, that should be fine, but you don't really need 750 watts for your system with upgrades. Also, the price seems really low. You're not looking at a used model are you?
just to verify here is the link https://www.galaxus.de/de/s1/produc...tm_source=idealo&idealoid=2011101234195381162
i was thinking that in the future i could put a r5 5600x in there along with some mid range gpu, thats why 750 ( as you said if its the part mentioned in the list then its a good deal for the price right ? )
I used google translate and it says the model is not currently available. Can you confirm this? If it is available it looks like a good deal.
it only states that the delivery date should be between 19-24 of november
also on the other parts im waiting just in case a good deal comes in but with this psu i might as well buy it now right ?
