Need pros/cons for two Gigabyte motherboards mATX vs. ATX
Maverick_
6
Hey guys. I would love to hear some opinions on these two boards, as I am upgrading to an Intel i5-4690k. My previous build used an ASRock ATX board. Is there a specific disadvantage to getting a mATX board versus an ATX? I am also not planning to use SLI with this build. Links to the two boards below:
Gigabyte GA-B85M-D3H mATX:
http://www.microcenter.com/single_product_results.aspx?sku=250431
Gigabyte GA-Z97X-SLI ATX:
http://www.microcenter.com/product/417842/GA-B85M-D3H_LGA_1150_mATX_Intel_Motherboard
The first is a B85 motherboard, so it will not overclock that cpu very well at'all, as well as not supporting functions like Sata-E, Next Gen Broadwell, and less PCI Lanes. (The Z97X does not have these disadvantages, i have used it in the past, and its bios is solid)
1. A M-ATX motherboard will perform just as well and will fit in a smaller case.
They will not have good spacing for dual graphics cards, but that is no issue for you.
2. With a "K" cpu, you will want a motherboard with a Z97 chipset so you can overclock.
As to individual brands, they are all good. Only if you will be seeking record level overclocks would a high priced enthusiast board be good.
