Need recomendation for Processor and motherboard for gaming PC
motoadve
35
I want a good gaming platform
A motherboard with good souncard included and DDR3
And a Good fast processor for around $300
I choose a 4850 X2 Ati as a graphics card
Core i7 920 2.66 Ghz CPU - can be OC'ed if you want to around 4.0 Ghz
Motherboard: Asus P6T i7 MOBO series- really anyone of those
cheap but good: ASUS P6T SE LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131386
More expensive: ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Best Expensive Mobo (well there are a few):
SLI God:EVGA 132-BL-E758-TR LGA 1366
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046
OCer's heaven: Foxconn BloodRage LGA 1366
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186163
now did you want all that for 300 bucks, or just the mobo? Because all of that for 300 just isn't possible. The closet i could get was 338$ using 2 gigs of ddr3 1333mhz, a phenom 2 x4 810@ 2.6 and a ECS black series AM3 mobo. if You do want a solid gaming system, might i suggest something like this...?
Proc
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115057
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135063
Ram (2 sticks of 2gigs)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146732
for 284$
First off, the Core2quads still kick the crap out of phenom 2. Upgrade
Mobo, decent sound, but if you want high end sound, you would be better off just buying a dedicated sound card.
4 gigs of ddr2 is still superior to 2 gigs of faster ddr3. There just isn't a big enough payoff for the price yet. Upgrade.
however, if I took this all wrong, go with nerrawg. His mobo choices are definitely good ones and worthy of being considered.
I want to spend $300 in the processor alone, get a good Motherboard with overclocking capability and a good integrated soundcard (good enough for gaming) and DDR3 preference i7 Intel CPU
1680x1050
usually play Flight Simulator X , and IL46
Why is this card not tested in this website's graphics benchmark?
And for that resolution, even these cards are overkill...but as the games become more graphics intensive, these should do a good job handling those as well at that resolution...
The GTX 275/ HD 4890 can handle resolutions upto 1900X1200 with ease at high settings in most of the current games...
For those games mate I would look at a GTS 250 1 GB or a GTX 260 - the GTX 275 will be a waste of money - even when Storm of War: Battle of Britain comes out. Better off getting these cheaper cards and then when DX11 and the new flight simulator comes out buy the new DX11 cards so you can play the latest. Because of DX11 the 275 and the 4890 will be obsolete with regards to fight simulator XI, if you play mainly flight sims then this is the best advice I can give. I play Il-2 1946 myself, as well as lock on and F4 AF and these games do not need anyway near the performance of that 275. FSX is the most demanding of the games you mentioned, and it is a bit weird compared to most games. It absolutely loves CPU power, so the core i7 is an excellent choice. XthekidX and I have advised people on FSX builds before:
http://www.tomshardware.com/forum/262847-31-need-choosing-motherboard
for example
What you tell me makes total sense.
So for now just a Ati 4870 be enough?Will it ran MS flight simulator X smoothly at the highest quality?
